Salta al contenuto principale
Samsung Refrigerator Door Sensors Replacement
Cosa ti serve
  1. Samsung Refrigerator Door Sensors Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Door Sensors Replacement, Remove the hinge cover: passo 2, immagine 1 di 1
    • Remove the screws securing the hinge cover (aka top table) on the top of the refrigerator.
  3. Samsung Refrigerator Door Sensors Replacement: passo 3, immagine 1 di 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung Refrigerator Door Sensors Replacement: passo 4, immagine 1 di 2 Samsung Refrigerator Door Sensors Replacement: passo 4, immagine 2 di 2
    • Use your fingers to release the wire connectors under the hinge cover.
    • Disconnect the wiring so you can remove the hinge cover.
  5. Samsung Refrigerator Door Sensors Replacement: passo 5, immagine 1 di 1
    • Remove the hinge cover.
  6. Samsung Refrigerator Door Sensors Replacement, Sensor information: passo 6, immagine 1 di 2 Samsung Refrigerator Door Sensors Replacement, Sensor information: passo 6, immagine 2 di 2
    • The door sensors are located in the hinge cover. In this example, the hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung Refrigerator Door Sensors Replacement, Remove the sensor: passo 7, immagine 1 di 2 Samsung Refrigerator Door Sensors Replacement, Remove the sensor: passo 7, immagine 2 di 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung Refrigerator Door Sensors Replacement: passo 8, immagine 1 di 2 Samsung Refrigerator Door Sensors Replacement: passo 8, immagine 2 di 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung Refrigerator Door Sensors Replacement: passo 9, immagine 1 di 1
    • Remove the door sensor.
Conclusione
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
Team Vulcan Membro di Team Vulcan
Staff
6 Membri
212 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 80
Ultimi 30 Giorni: 435
Tutti i Tempi: 10,256
