Salta al contenuto principale
Samsung Refrigerator Control Panel Replacement
Cosa ti serve
  1. Samsung Refrigerator Control Panel Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: passo 2, immagine 1 di 2 Samsung Refrigerator Control Panel Replacement, Open the refrigerator doors: passo 2, immagine 2 di 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Control Panel Replacement, Loosen the control panel: passo 3, immagine 1 di 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: passo 3, immagine 2 di 3 Samsung Refrigerator Control Panel Replacement, Loosen the control panel: passo 3, immagine 3 di 3
    • The control panel has plastic clips around its perimeter that secure it to the refrigerator wall.
    • Insert a spudger into the seam along the right edge of the control panel.
    • You can also use a flathead screwdriver, but be careful not to let the screwdriver slip, or you'll scratch your refrigerator surface.
    • Press the spudger in firmly and pry to loosen the panel.
    • Use your spudger to slide and pry around the control panel to loosen it from the refrigerator wall.
  4. Samsung Refrigerator Control Panel Replacement: passo 4, immagine 1 di 1
    • Flip the control panel over to reveal the cable connector.
  5. Samsung Refrigerator Control Panel Replacement: passo 5, immagine 1 di 2 Samsung Refrigerator Control Panel Replacement: passo 5, immagine 2 di 2
    • Use your fingers to slide the cable connector out of its socket.
  6. Samsung Refrigerator Control Panel Replacement, Remove the control panel: passo 6, immagine 1 di 1
    • Remove the control panel.
Conclusione
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Membro da: 04/14/15
15.945 Reputazione
89 Guide realizzate
Team Vulcan Membro di Team Vulcan
Staff
6 Membri
212 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 99
Tutti i Tempi: 3,465
