Salta al contenuto principale
Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement
Cosa ti serve
  1. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Open the freezer drawer: passo 2, immagine 1 di 1
    • Slide the freezer drawer fully open.
  3. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer bins: passo 3, immagine 1 di 1
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: passo 4, immagine 1 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: passo 4, immagine 2 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: passo 4, immagine 3 di 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 5, immagine 1 di 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 5, immagine 2 di 2
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
  6. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer compartment evaporator cover: passo 6, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 16.2 mm-long screws securing the freezer evaporator cover.
  7. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 7, immagine 1 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 7, immagine 2 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 7, immagine 3 di 3
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 8, immagine 1 di 2 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 8, immagine 2 di 2
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 9, immagine 1 di 1
    • Remove the evaporator cover.
  10. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: passo 10, immagine 1 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: passo 10, immagine 2 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: passo 10, immagine 3 di 3
    • Guide the fan cable from the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  11. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 11, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 18.3 mm-long screws securing the back panel to the evaporator cover.
  12. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 12, immagine 1 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 12, immagine 2 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 12, immagine 3 di 3
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  13. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 13, immagine 1 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 13, immagine 2 di 3 Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 13, immagine 3 di 3
    • Lift and separate the back panel from the evaporator cover.
  14. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 14, immagine 1 di 1
    • Use a Phillips screwdriver to remove the three 14.2 mm-long screws securing the fan to the evaporator cover.
  15. Samsung RF28R7201SG Refrigerator Evaporator Fan (Freezer Compartment) Replacement: passo 15, immagine 1 di 1
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Conclusione
Repair didn’t go as planned? Ask our Answers community for help.
nicO
Membro da: 04/14/15
15.927 Reputazione
88 Guide realizzate
Global Fixers Membro di Global Fixers
Community
34 Membri
593 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 296
