Salta al contenuto principale
Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement
Cosa ti serve
  1. Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 2, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 3, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 4, immagine 1 di 2 Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 5, immagine 1 di 3 Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 5, immagine 2 di 3 Samsung Notebook 7 Spin NP740U3MK01US Battery Replacement: passo 5, immagine 3 di 3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
Conclusione
Altre 6 persone hanno completato questa guida.
Un commento
This is a great guide. Where do I purchase the battery from as I’m not finding it on this website?
Jay Hernandez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 38
Tutti i Tempi: 4,749
