Salta al contenuto principale
Samsung NP900X4B Battery Replacement
Cosa ti serve
  1. Samsung NP900X4B Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung NP900X4B Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung NP900X4B Battery Replacement: passo 2, immagine 1 di 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung NP900X4B Battery Replacement: passo 3, immagine 1 di 2 Samsung NP900X4B Battery Replacement: passo 3, immagine 2 di 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung NP900X4B Battery Replacement: passo 4, immagine 1 di 1
    • Lift and pull out the battery.
Conclusione
Nathan LeBlanc
Membro da: 10/17/18
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 606
