Salta al contenuto principale
Samsung NP510R5E-A01UB Display Replacement
Cosa ti serve
  1. Samsung NP510R5E-A01UB Display Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Display Replacement: passo 2, immagine 1 di 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Display Replacement: passo 3, immagine 1 di 2 Samsung NP510R5E-A01UB Display Replacement: passo 3, immagine 2 di 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Display Replacement, Display: passo 4, immagine 1 di 3 Samsung NP510R5E-A01UB Display Replacement, Display: passo 4, immagine 2 di 3 Samsung NP510R5E-A01UB Display Replacement, Display: passo 4, immagine 3 di 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Display Replacement: passo 5, immagine 1 di 2 Samsung NP510R5E-A01UB Display Replacement: passo 5, immagine 2 di 2
    • Disconnect the black and white cables by pulling up as pictured.
  6. Samsung NP510R5E-A01UB Display Replacement: passo 6, immagine 1 di 2 Samsung NP510R5E-A01UB Display Replacement: passo 6, immagine 2 di 2
    • Disconnect the black cable by pulling straight out.
  7. Samsung NP510R5E-A01UB Display Replacement: passo 7, immagine 1 di 3 Samsung NP510R5E-A01UB Display Replacement: passo 7, immagine 2 di 3 Samsung NP510R5E-A01UB Display Replacement: passo 7, immagine 3 di 3
    • Unscrew the two 4.45mm long screws to disconnect the left hinge.
    • Unscrew the two 4.45mm long screws to disconnect the right hinge.
    • At this point the screen and plastic housing should be completely disconnected.
  8. Samsung NP510R5E-A01UB Display Replacement: passo 8, immagine 1 di 2 Samsung NP510R5E-A01UB Display Replacement: passo 8, immagine 2 di 2
    • Using the plastic opening tool, pry open the plastic housing that holds the display.
  9. Samsung NP510R5E-A01UB Display Replacement: passo 9, immagine 1 di 2 Samsung NP510R5E-A01UB Display Replacement: passo 9, immagine 2 di 2
    • Unscrew the four 3.55mm long screws that hold the display in place.
  10. Samsung NP510R5E-A01UB Display Replacement: passo 10, immagine 1 di 2 Samsung NP510R5E-A01UB Display Replacement: passo 10, immagine 2 di 2
    • Disconnect the last cable by pulling straight out.
Conclusione
Dominic Simpson
Membro da: 02/14/18
245 Reputazione
1 Guida realizzata
USF Tampa, Team S6-G5, Eyestone Spring 2018 Membro di USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 659
