Introduzione
Use this guide to fix a cracked or damaged top glass for the Samsung Galaxy Z Flip.
Cosa ti serve
Prepare an iOpener and apply it to the left edge of the phone for one minute.
Apply a suction cup to the glass.
Push down on the metal part on the hinge while pulling up on the glass until the glass begins to separate from the frame.
Insert an opening pick into the gap between the glass and the frame.
Begin sliding the pick down to the corner of the phone to slice the adhesive
Repeat previous heating instructions for each side of the phone.
Leave an opening pick in each corner as you cut the adhesive around the phone.
Lift up the rear glass of the phone to from the far left side of the phone to risk damaging the ribbon cable.
Use a Uspudger to remove the plastic bracket covering the connector.
Use a spudger to disconnect the ribbon cable from the board.
