Salta al contenuto principale
Samsung Galaxy Tab S 10.5 Display Replacement
Cosa ti serve
  1. Samsung Galaxy Tab S 10.5 Display Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: passo 1, immagine 1 di 2 Samsung Galaxy Tab S 10.5 Display Replacement, Disassembling Galaxy Tab S 10.5 Back Cover: passo 1, immagine 2 di 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 10.5 Display Replacement: passo 2, immagine 1 di 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Samsung Galaxy Tab S 10.5 Display Replacement: passo 3, immagine 1 di 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
  4. Samsung Galaxy Tab S 10.5 Display Replacement, Display: passo 4, immagine 1 di 2 Samsung Galaxy Tab S 10.5 Display Replacement, Display: passo 4, immagine 2 di 2
    • After taking off the back cover, use a pair of tweezers to disconnect the two (T807) ribbons.
    • Warning : Ribbon cables are connected with ZIF connectors (Zero Insertion Force): it requires a special sequence with rotation of a plastic lever to release the pressure on contacts. Then ribbon cable can be extracted without any damage.
  5. Samsung Galaxy Tab S 10.5 Display Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Tab S 10.5 Display Replacement: passo 5, immagine 2 di 2
    • Remove the four screws holding down the battery using the Phillips #000 screwdriver.
  6. Samsung Galaxy Tab S 10.5 Display Replacement: passo 6, immagine 1 di 2 Samsung Galaxy Tab S 10.5 Display Replacement: passo 6, immagine 2 di 2
    • Remove the battery using a spudger.
    • Do not use a metal spudger on the inner components of your device. The metal spudger should only be used for serious prying power as it can damage the inner components of your device.
  7. Samsung Galaxy Tab S 10.5 Display Replacement: passo 7, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the screw holding the motherboard.
  8. Samsung Galaxy Tab S 10.5 Display Replacement: passo 8, immagine 1 di 2 Samsung Galaxy Tab S 10.5 Display Replacement: passo 8, immagine 2 di 2
    • Disconnect the motherboard and remove it from the device using the spudger.
    • The remainder of the device is the entire display assembly.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 63
Tutti i Tempi: 4,410
