Salta al contenuto principale
Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement
Cosa ti serve
  1. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: passo 1, immagine 1 di 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: passo 1, immagine 2 di 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: passo 1, immagine 3 di 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 2, immagine 2 di 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: passo 3, immagine 1 di 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: passo 3, immagine 2 di 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: passo 3, immagine 3 di 3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 6, immagine 1 di 1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: passo 8, immagine 3 di 3
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: passo 9, immagine 1 di 2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: passo 9, immagine 2 di 2
    • Use a soldering iron to heat 4 spots of solder from the motherboard.
    • To learn more about soldering, check out iFixit's soldering technique guide.
    • Use precision tweezers to remove the charging port.
Conclusione
USF Tampa, Team S19-G2, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,573
