Salta al contenuto principale
Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement
Cosa ti serve
  1. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Back Casing: passo 1, immagine 1 di 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 3, immagine 3 di 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Front Panel: passo 4, immagine 1 di 2 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Front Panel: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard.
    • To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
  5. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 5, immagine 1 di 1
    • Once you've undone the connector lock, use a pair of tweezers to pull the cable front its housing.
  6. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 6, immagine 1 di 1
    • Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
    • You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
    • Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
  7. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Home Button: passo 7, immagine 1 di 1
    • Unlock the ZIF connector to release ribbon cable that lays across the battery.
  8. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 8, immagine 1 di 1
    • Gray padding covers the ribbon wires connected to the home button. Before removing the wires, gently remove the padding with tweezers.
  9. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 9, immagine 3 di 3
    • To remove the home button for replacement, locate a strip of ribbon wire on the back of the tablet at the bottom.
    • Using the tweezers, slowly pull the ribbon wire, being careful to not rip the wire or damage any surrounding parts.
    • Underneath the home button, you will find more ribbon wire. Do not remove this ribbon wire until the home button has been removed.
  10. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: passo 10, immagine 2 di 2
    • Once the ribbon wire has been disconnected from the back, flip the tablet over to remove the home button.
    • Using tweezers, securely grab the home button and pull until it has been removed. You should now be able to see the remainder of the ribbon wire.
    • If the ribbon wire is the reason for the faulty home button, remove the remainder of it and replace it with a new ribbon wire.
Conclusione
To reassemble your device, reverse the steps in the instructions.
USF Tampa, Team 1-4, Cagle Fall 2016 Membro di USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,437
