Salta al contenuto principale
Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement, Back Casing: passo 1, immagine 1 di 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 3, immagine 3 di 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement, Front Camera: passo 4, immagine 1 di 1
    • The front camera is located at the top, middle of the motherboard. The red rectangle in the image to the left depicts its location.
  5. Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Tab E 9.6 Verizon Front Camera Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the ribbon wires connecting the camera to the motherboard by using tweezers to flip the black latch away from the camera (towards the bottom of the tablet).
    • Carefully pull the camera out.
Conclusione
USF Tampa, Team 1-4, Cagle Fall 2016 Membro di USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 789
