Salta al contenuto principale
Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement
Cosa ti serve
  1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: passo 1, immagine 1 di 2 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 2, immagine 1 di 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 2, immagine 2 di 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 2, immagine 3 di 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 3, immagine 1 di 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 3, immagine 2 di 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 3, immagine 3 di 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: passo 4, immagine 1 di 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: passo 4, immagine 2 di 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: passo 4, immagine 3 di 3
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
    • Use the plastic opening tool to remove the motherboard from the case.
  5. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 5, immagine 1 di 2 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 5, immagine 2 di 2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while prying upwards until the screen separates from the bezel.
    • The screen may crack during this process so be wary of broken glass.
    • Applying heat may be necessary to loosen the glue.
Conclusione
Altre 4 persone hanno completato questa guida.
Guneet Bawa
Membro da: 04/12/18
688 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G5, Liner Spring 2018 Membro di UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,354
