Salta al contenuto principale
Samsung Galaxy Tab 4 10.1 IR Sensor Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, Battery: passo 1, immagine 1 di 2 Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, Battery: passo 1, immagine 2 di 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: passo 2, immagine 1 di 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: passo 4, immagine 1 di 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: passo 5, immagine 1 di 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: passo 6, immagine 1 di 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, IR Sensor: passo 7, immagine 1 di 2 Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, IR Sensor: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the IR sensor press-fit connector from the motherboard.
  8. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: passo 8, immagine 1 di 1
    • Remove the IR sensor.
Conclusione
Blake Klein
Membro da: 01/29/17
69.006 Reputazione
51 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 570
