Salta al contenuto principale
Samsung Galaxy Tab 3 Kids Battery Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Before beginning this repair, make sure that the device is completely turned off.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 2, immagine 2 di 2
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 3, immagine 2 di 2
    • Remove the four 1.2 mm Phillips #000 screws surrounding the battery.
  4. Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 4, immagine 2 di 2
    • Use your hands to gently lift the battery up to remove it.
    • If it does not come off easily, there may be some glue underneath the battery and may need to be pried off with a spudger.
Conclusione
Altre 4 persone hanno completato questa guida.
ajhoffman
Membro da: 01/04/14
182 Reputazione
5 Guide realizzate
USF Tampa, Team 2-6, Nance Fall 2016 Membro di USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
4 Membri
10 Guide realizzate
2 Commenti
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - Replica
my screen broke
galixyman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,985
