Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Turn off the power to the device before removing the back case. Use a plastic tool to release the screen from the plastic case.
    • Turn off the power to the device before removing the back case.
    • Use a plastic tool to release the screen from the plastic case.
  2. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Disconnect the battery using a spudger. Pry up gently on both sides to release the connector (marked in green). Remove the tape covering the zif connector (marked in red)
    • Disconnect the battery using a spudger. Pry up gently on both sides to release the connector (marked in green).
    • Remove the tape covering the zif connector (marked in red)
  4. Disconnect the cable on the left of the charger (marked in green).
    • Disconnect the cable on the left of the charger (marked in green).
    • Remove the two philips screws that secure the charger port in place (marked in red).
    Is it worth changing the battery while repairing the charger port
    Victoria Watson - Replica
    If the battery is more than two years old I'd highly recommend it.
    Evan Noronha -
Conclusione
Altre 16 persone hanno completato questa guida.
Harvey
Membro da: 15/02/2016
3.093 Reputazione
6 Guide realizzate
Where would I purchase the charger port and what is the tell tale sign that the charger port is the problem.
Do you know how much this part is
Kind regards
Victoria
Normally you can find it online at any electronics parts supplier......or eBay. the part itself isn't too expensive but will depend which country you live in.
Harvey - Replica
Step 3 How do you disconnect the cable from the charge port?
shaneflavell - Replica
I have replaced the charger, but I have the problem that loads very slowly or the computer does not reconkce the tablet
Edwin Chévez - Replica
It could be the charger port is defective, even though it is new.
Have you tried another charger cable and plug? It will charge quicker over mains power than over USB charging.
If the computer doesn’t recognize it either, then I would guess that the new part is probably defective, if it was recognized with the old part before.
Harvey -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 9,539
