Salta al contenuto principale
Samsung Galaxy S8 Plus SIM Card or SD Card Replacement
Cosa ti serve
  1. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement, SIM Card or SD Card: passo 1, immagine 1 di 2 Samsung Galaxy S8 Plus SIM Card or SD Card Replacement, SIM Card or SD Card: passo 1, immagine 2 di 2
    • The SIM card tray's ejection hole looks almost exactly like the microphone hole, located just a short distance away. Insert your tool only where indicated. Inserting your tool into the microphone hole may result in permanent microphone damage.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, on the top edge of the phone.
    • Press firmly to eject the tray.
  2. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement: passo 2, immagine 1 di 2 Samsung Galaxy S8 Plus SIM Card or SD Card Replacement: passo 2, immagine 2 di 2
    • Grab the tray and pull straight out to remove it.
    • SIM and/or SD cards will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket near the outer end of the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket to protect your phone's internal components.
Conclusione
After you've completed the repair, follow this guide to test your repair.
Altre 6 persone hanno completato questa guida.
Jeff Suovanen
Membro da: 08/06/13
428.515 Reputazione
259 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.198 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 187
Tutti i Tempi: 17,823
