Salta al contenuto principale
Samsung Galaxy S7 Active Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy S7 Active Motherboard Replacement, Samsung Galaxy S7 Active Disassembly: passo 1, immagine 1 di 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Motherboard Replacement: passo 2, immagine 1 di 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S7 Active Motherboard Replacement: passo 3, immagine 2 di 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Motherboard Replacement: passo 4, immagine 1 di 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Motherboard Replacement, Battery: passo 5, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Motherboard Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Motherboard Replacement: passo 7, immagine 1 di 1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Motherboard Replacement: passo 8, immagine 1 di 1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Motherboard Replacement: passo 9, immagine 1 di 1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Motherboard Replacement: passo 10, immagine 1 di 1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Galaxy S7 Active Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Galaxy S7 Active Motherboard Replacement: passo 11, immagine 3 di 3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Motherboard Replacement: passo 12, immagine 1 di 2 Samsung Galaxy S7 Active Motherboard Replacement: passo 12, immagine 2 di 2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
  13. Samsung Galaxy S7 Active Motherboard Replacement, Rear Camera: passo 13, immagine 1 di 1
    Compra
    • Use tweezers to disconnect the front camera from the battery.
    • The connector should unsnap similar to a lego piece.
  14. Samsung Galaxy S7 Active Motherboard Replacement, Motherboard: passo 14, immagine 1 di 1
    • Use a Phillips 000 screwdriver to remove the screw covering the proximity sensor.
  15. Samsung Galaxy S7 Active Motherboard Replacement: passo 15, immagine 1 di 2 Samsung Galaxy S7 Active Motherboard Replacement: passo 15, immagine 2 di 2
    Compra
    • Use tweezers to remove the proximity sensor.
    • Set this aside for now.
  16. Samsung Galaxy S7 Active Motherboard Replacement: passo 16, immagine 1 di 1
    • Use tweezers to disconnect the front mic and the two cables that have been marked in the photo.
  17. Samsung Galaxy S7 Active Motherboard Replacement: passo 17, immagine 1 di 1
    • Use your hands and a metal spudger to lift the motherboard out of the phone.
    • Be gentle, as there is still a connection on the underside of the motherboard.
    • Use a metal spudger to remove this connection.
Conclusione
Altre 3 persone hanno completato questa guida.
Joe De Leone
Membro da: 04/18/18
310 Reputazione
3 Guide realizzate
Cal Poly, Team S18-G1, Livingston Spring 2018 Membro di Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 38
Tutti i Tempi: 5,260
