Salta al contenuto principale
Samsung Galaxy S7 Active Battery Replacement
Cosa ti serve
  1. Samsung Galaxy S7 Active Battery Replacement, Samsung Galaxy S7 Active Disassembly: passo 1, immagine 1 di 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Battery Replacement: passo 2, immagine 1 di 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Battery Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S7 Active Battery Replacement: passo 3, immagine 2 di 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Battery Replacement: passo 4, immagine 1 di 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Battery Replacement: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Battery Replacement: passo 7, immagine 1 di 1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Battery Replacement: passo 8, immagine 1 di 1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Battery Replacement: passo 9, immagine 1 di 1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Battery Replacement: passo 10, immagine 1 di 1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Battery Replacement: passo 11, immagine 1 di 3 Samsung Galaxy S7 Active Battery Replacement: passo 11, immagine 2 di 3 Samsung Galaxy S7 Active Battery Replacement: passo 11, immagine 3 di 3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Battery Replacement: passo 12, immagine 1 di 2 Samsung Galaxy S7 Active Battery Replacement: passo 12, immagine 2 di 2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
Conclusione
Altre 11 persone hanno completato questa guida.
Cal Poly, Team S18-G1, Livingston Spring 2018 Membro di Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Membri
15 Guide realizzate
3 Commenti
I would advise against using a metal spudger to remove the battery itself. While working at a device repair chain in the past, a coworker of mine punctured a battery with a metal spudger and destroyed the phone. Instead, use a sturdy plastic spudger to remove the battery. Otherwise, great guide!
Derek Margheim - Replica
I got the battery fixed but shattered my screen wish it was more informative on how to get out the screen
joshua hofer - Replica
Would using the Anti-clamp with heat gun be better option?
Kiriakos White - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 109
Tutti i Tempi: 24,735
