Introduzione
For the official iFixit guide to repair your Galaxy S5 display, click here. The guide you are currently viewing is duplicate content, archived here for historical purposes only.
Cosa ti serve
Remove the rear case by using moderate force to pry the divot on the left of the rear facing camera with a plastic opening tool or your fingernail.
Continue to lift the case, working your way around the perimeter until the entire rear cover is removed.
Gently slide out the SD card using your fingernail or a plastic opening tool.
Lay the iOpener flat on the bottom of the device, directly over the home button. Smooth the iOpener along the surface to ensure good contact with the device. Leave the bag on the device for around 90 seconds.
Repeat the process laying the bag on the left and right edge of the screen.
Use a light amount of force when removing the screen.
Starting at the top of the device, work the plastic opening tool under the screen. The top of the device has the Samsung logo and headphone port.
Start separating the screen from the glue. Work your way around the screen until the glue is no longer holding the screen in place.
During this operation I destroyed display. Display was glued from back to the phon. So if you even softly touch it, it will crack.
Start lifting the screen from the top. You will see a black ribbon cable attaching the display to the motherboard. Use the plastic opening tool to lightly detach the connector.
Continue to lift the display. You will notice a black cable connecting the home button to the motherboard.
Use the plastic opening tool to pry the home button off. Moderate force is required.
When gluing the home button back to the display, is there a particular glue I should use?
Altre 68 persone hanno completato questa guida.
11 Commenti
Or the galaxy S5 as well?
How do I get a new light to light up my screen as I'm hoping I can use it n just change the light
My S5 fell down and and after some hours there appears ink on the screen. Please what is wrong? Do I need to change the whole screen or is there a unit that brings out ink and have to change only that unit only?
Hi did you find out what causes this? i had the same issue my phone fell and the scree looks like ink dropped inside of it
jochmejr -
lol the digitizer is the glass and there is no ink in displays your lcd is fukd you need to replace the entire screen assembly
Nice work for my phone setting
BhupSinghBhadu Baf - Replica
Thanks very much A better replace ment
