Salta al contenuto principale
Samsung Galaxy S10e SIM/Micro SD Card Tray Replacement
Cosa ti serve
  1. Samsung Galaxy S10e SIM/Micro SD Card Tray Replacement, Eject the SIM/Micro SD tray: passo 1, immagine 1 di 2 Samsung Galaxy S10e SIM/Micro SD Card Tray Replacement, Eject the SIM/Micro SD tray: passo 1, immagine 2 di 2
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a different hole, don’t worry! You most likely haven’t damaged anything.
    • Press firmly to eject the tray.
  2. Samsung Galaxy S10e SIM/Micro SD Card Tray Replacement, Remove the SIM/Micro SD tray: passo 2, immagine 1 di 2 Samsung Galaxy S10e SIM/Micro SD Card Tray Replacement, Remove the SIM/Micro SD tray: passo 2, immagine 2 di 2
    • Pull the tray straight out to remove it.
Conclusione
After you've completed the repair, follow this guide to test your repair.
Arthur Shi
Membro da: 01/03/18
254.682 Reputazione
529 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.439 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 937
