Introduzione
The Galaxy S10+ has a hybrid SIM card tray. Ejecting this tray allows you to replace the nano SIM card, add a MicroSD memory card, or add a second nano SIM card (certain models only).
Cosa ti serve
Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
Press firmly to eject the tray.
Remove the SIM card tray.
After you've completed the repair, follow this guide to test your repair.
Altre 4 persone hanno completato questa guida.
5 Commenti
I have the same question. I'm sure you've taken enough of these apart for repair. (Galaxy s10's and pluses) Can you guys see what's at the end of the hole? Any research that I've found says that the hole is straight and comes to an end and the microphone is 90° to that, so it cannot be poked by the pin, is this true? (I hope it is, and to give us peace of mind!) I don't want to have to take apart my phone. I'm sure there are lots people out here that have poked this %#*@ hole and are freaking that we have wrecked a $1600.00 phone! And then, if you could kindly please then post an answer plainly in the instructions for the SIM installation somewhere in the body of this installation article. I have seen no definitive answer to this mistake in any other article that I've read. Ifixit is the premiere repair company for phones, this should be solved here. Thanks in advance I hope. I've used your services multiple times in the past for various breakages of our family phones in Chicago, you've always been great.
Hi Lin,
Please look for the answer in step 1’s comments.
I inserted the pin in the microphone hole first. Thank you for setting my mind at ease that I didn’t damage anything,
well we have a dilemma here my s10+ ihas got a micro sim card stuck in the sd slot see if you can get it out by taking the phone apartand also ill need directions to you
