Salta al contenuto principale
Samsung Galaxy S III Battery Replacement
Cosa ti serve
  1. Samsung Galaxy S III Battery Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Galaxy S III Battery Replacement, Rear Case: passo 1, immagine 2 di 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Battery Replacement: passo 2, immagine 1 di 2 Samsung Galaxy S III Battery Replacement: passo 2, immagine 2 di 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Battery Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S III Battery Replacement: passo 3, immagine 2 di 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Battery Replacement: passo 4, immagine 1 di 2 Samsung Galaxy S III Battery Replacement: passo 4, immagine 2 di 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Battery Replacement: passo 5, immagine 1 di 2 Samsung Galaxy S III Battery Replacement: passo 5, immagine 2 di 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Battery Replacement, Battery: passo 6, immagine 1 di 2 Samsung Galaxy S III Battery Replacement, Battery: passo 6, immagine 2 di 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Battery Replacement: passo 7, immagine 1 di 2 Samsung Galaxy S III Battery Replacement: passo 7, immagine 2 di 2
    • Remove the battery.
Conclusione
Altre 90 persone hanno completato questa guida.
3 Commenti
Do I have to wait after replacing it or can I use my phone right away? If so how long
ivon200021 - Replica
Super simple. Thanks!
bmwherry - Replica
I don't get it why you insist it takes at least 2 minutes. I've done it in 5 seconds multiple times using fingers and no tabs have ever broken off. It literally takes 5-10 seconds, you just pull it off.
Krzeszny - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 70
Tutti i Tempi: 64,934
