Salta al contenuto principale
Samsung Galaxy S Blaze Volume Rocker Replacement
Cosa ti serve
  1. Samsung Galaxy S Blaze Volume Rocker  Replacement, Volume Rocker: passo 1, immagine 1 di 1
    • Start by removing the back plate to expose the battery by pulling the back and front plates apart.
  2. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the device and set aside.
  3. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 3, immagine 2 di 2
    • Using a Phillips Head Screwdriver size 00. Remove all eight 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 4, immagine 1 di 1
    • Remove the frame from the phone by prying it off with the iFixit blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 5, immagine 1 di 2 Samsung Galaxy S Blaze Volume Rocker  Replacement: passo 5, immagine 2 di 2
    • The volume rocker is held into the frame by two small prongs.
    • Carefully unhook the prongs from the frame by pulling to the side and remove the volume rocker.
    • The prongs on the volume rocker look like this.
Conclusione
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 327
