Introduzione
Follow this guide to remove and replace the motherboard in the Samsung Galaxy Note5.
Cosa ti serve
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray at the top of the phone.
Press to eject the tray. This may require some force.
Remove the SIM card tray.
Using your fingernail, push the S-Pen button until it clicks and pops out of the phone.
Remove the S-Pen.
Hola mi priblema es que meti al reves el spen en el orificio y al sacarlo pues ya no funciona …. Tiene reparacion es un galaxy note 5
Apply a heated iOpener to the bottom of the phone for about two minutes.
Apply a suction cup as close as possible to the bottom edge of the phone.
Lift on the suction cup and insert an opening pick under the rear glass.
Yes very fragile, i dont know how to remove without cracking the glass back.
It IS possible, because I just did it. You have to be extremely patient and use firm but gentle pressure. It took me nearly an hour just to get the back off.
One more thing: I discovered that the only way that I could get enough heat into it to soften the adhesive it is to fold the hot iOpener so that you heat from both sides.
Attrezzo utilizzato in questo passaggio:Tesa 61395 Tape$5.99
Use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Remove the twenty 3.3 mm Phillips screws.
the phone was gave to me and I bought a replacement battery but two of the screw around the camera won't come out it's like their stripped what do I do
Hold the midframe by the edges and lift it upwards while pushing down against the battery with one finger.
Remove the midframe.
During this step, I destroyed my phone. Some of the circuit board at the bottom of the battery is attached to the mid-frame. When I pushed on the battery as instructed, it broke apart. The phone is useless.
Hi Edward,
I’m sorry to hear that! My guess would be that a stray screw held the board to the midframe. If your phone had an extra screw that I missed, please notify me and I’ll correct it!
Using the flat end of a spudger, lift the battery connector straight up from its socket on the motherboard.
Altre 6 persone hanno completato questa guida.
