Introduzione
Use this guide to remove the back cover and the fingerprint sensor on your Samsung Galaxy M31.
You’ll need replacement adhesive to reattach the fingerprint sensor when reassembling the device.
Cosa ti serve
Insert a SIM card eject tool, a SIM eject bit or a straightened paper clip into the hole on the SIM tray located at the left side of the phone.
Press firmly to eject the tray.
Apply a heated iOpener to the back of the phone where the fingerprint sensor is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the fingerprint sensor with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 6 persone hanno completato questa guida.
2 Commenti
What type of adhesive is best to use to stick the back cover back on. Glue or tape?
лучше если останется заводской скотч.
если вы его убрали то используйте 3m скотч.
если вы заклеите на клей то потом крйне сложно будет отклеить заднюю крышку.
