Salta al contenuto principale
Samsung Galaxy A20 Charging Port Replacement
Cosa ti serve
  1. Samsung Galaxy A20 Charging Port Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung Galaxy A20 Charging Port Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung Galaxy A20 Charging Port Replacement, Back Cover: passo 1, immagine 3 di 3
    • Unplug and power off the device before beginning.
    • Remove the SIM card and the SIM card tray.
    • Use an iOpener or heat gun to warm the adhesive that secures the back cover.
    • Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
    • Slide the pick around the entire perimeter.
    • If you encounter notable resistance, reheat the adhesive. Do not attempt to sever cold adhesive.
    • Remove the back cover.
  2. Samsung Galaxy A20 Charging Port Replacement, I/O Board: passo 2, immagine 1 di 2 Samsung Galaxy A20 Charging Port Replacement, I/O Board: passo 2, immagine 2 di 2
    • Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
    • Use an opening pick to pry up and lift out the midframe.
  3. Samsung Galaxy A20 Charging Port Replacement: passo 3, immagine 1 di 1
    • Use an opening tool to gently pry up the press connectors on both ends of the two ribbon cables.
  4. Samsung Galaxy A20 Charging Port Replacement: passo 4, immagine 1 di 2 Samsung Galaxy A20 Charging Port Replacement: passo 4, immagine 2 di 2
    • Disconnect the red antenna cable from the I/O board.
    • Use an opening pick to pry up and remove the I/O board.
  5. Samsung Galaxy A20 Charging Port Replacement, Charging Port: passo 5, immagine 1 di 2 Samsung Galaxy A20 Charging Port Replacement, Charging Port: passo 5, immagine 2 di 2
    • Desolderthe charging port.
    • Soldering can cause fires and burns. Always solder in a well-ventilated workspace.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 73
Tutti i Tempi: 88
