Introduzione
This guide gives instructions not only for removing a broken charging port but also for replacing it with a brand-new one. This will be helpful mainly when a device is not charging properly or if there is any damage to the charging port itself. This guide is tedious and requires skills with a soldering iron.
Special Skills
- Heat gun usage
- Soldering iron usage
Cosa ti serve
Remove the SIM card and the SIM card tray.
Use an iOpener or heat gun to warm the adhesive that secures the back cover.
Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
Slide the pick around the entire perimeter.
Remove the back cover.
Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
Use an opening pick to pry up and lift out the midframe.
