Salta al contenuto principale
Samsung Chromebook 3 Motherboard Replacement
Cosa ti serve
  1. Samsung Chromebook 3 Motherboard Replacement, Bottom Case: passo 1, immagine 1 di 2 Samsung Chromebook 3 Motherboard Replacement, Bottom Case: passo 1, immagine 2 di 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Motherboard Replacement: passo 2, immagine 1 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 2, immagine 2 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 2, immagine 3 di 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Motherboard Replacement: passo 3, immagine 1 di 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Motherboard Replacement, Battery: passo 4, immagine 1 di 2 Samsung Chromebook 3 Motherboard Replacement, Battery: passo 4, immagine 2 di 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Motherboard Replacement: passo 5, immagine 1 di 2 Samsung Chromebook 3 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Motherboard Replacement: passo 6, immagine 1 di 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Motherboard Replacement, Motherboard: passo 7, immagine 1 di 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: passo 7, immagine 2 di 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: passo 7, immagine 3 di 3
    • Before you can get to the motherboard, remove the three 4.6mm screws from the port cover using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 Motherboard Replacement: passo 8, immagine 1 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 8, immagine 2 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 8, immagine 3 di 3
    • Then, use a spudger to begin flipping up the grey covers on the ZIF connectors.
  9. Samsung Chromebook 3 Motherboard Replacement: passo 9, immagine 1 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 9, immagine 2 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 9, immagine 3 di 3
    • Two more ZIF connectors to go!
  10. Samsung Chromebook 3 Motherboard Replacement: passo 10, immagine 1 di 2 Samsung Chromebook 3 Motherboard Replacement: passo 10, immagine 2 di 2
    • Use a spudger to disconnect the cables going to the speaker by prying outward to the right.
  11. Samsung Chromebook 3 Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Chromebook 3 Motherboard Replacement: passo 11, immagine 3 di 3
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Then gently coax the display cable from its connector using your fingers or a spudger.
  12. Samsung Chromebook 3 Motherboard Replacement: passo 12, immagine 1 di 2 Samsung Chromebook 3 Motherboard Replacement: passo 12, immagine 2 di 2
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
  13. Samsung Chromebook 3 Motherboard Replacement: passo 13, immagine 1 di 1
    • Ensure all cables are clear and remove the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
Austin Blakely
Membro da: 03/11/19
17.287 Reputazione
52 Guide realizzate
iFixit Membro di iFixit
Community
141 Membri
17.757 Guide realizzate
Un commento
Thanks for the great guide! I used it to remove the write protection screw on the back of the motherboard.
My Chromebook is model number XE501C13. The only difference I noticed is that there is one less screw on the outer plastic cover. Everything else is exactly the same!
Edward Fernandez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 55
Tutti i Tempi: 2,518
