Salta al contenuto principale
Samsung 500C ChromeBook Battery Replacement
Cosa ti serve
  1. Samsung 500C ChromeBook Battery Replacement, Battery: passo 1, immagine 1 di 2 Samsung 500C ChromeBook Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: passo 2, immagine 1 di 3 Samsung 500C ChromeBook Battery Replacement: passo 2, immagine 2 di 3 Samsung 500C ChromeBook Battery Replacement: passo 2, immagine 3 di 3
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
Conclusione
Altre 3 persone hanno completato questa guida.
3 Commenti
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Replica
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - Replica
Don't show my NAME
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,234
