Salta al contenuto principale
Samsung 27E510C VGA Port Replacement
Cosa ti serve
  1. Samsung 27E510C VGA Port Replacement, Back Panel: passo 1, immagine 1 di 3 Samsung 27E510C VGA Port Replacement, Back Panel: passo 1, immagine 2 di 3 Samsung 27E510C VGA Port Replacement, Back Panel: passo 1, immagine 3 di 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C VGA Port Replacement: passo 2, immagine 1 di 2 Samsung 27E510C VGA Port Replacement: passo 2, immagine 2 di 2
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C VGA Port Replacement, Motherboard: passo 3, immagine 1 di 1
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C VGA Port Replacement: passo 4, immagine 1 di 1
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C VGA Port Replacement: passo 5, immagine 1 di 3 Samsung 27E510C VGA Port Replacement: passo 5, immagine 2 di 3 Samsung 27E510C VGA Port Replacement: passo 5, immagine 3 di 3
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C VGA Port Replacement: passo 6, immagine 1 di 3 Samsung 27E510C VGA Port Replacement: passo 6, immagine 2 di 3 Samsung 27E510C VGA Port Replacement: passo 6, immagine 3 di 3
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C VGA Port Replacement: passo 7, immagine 1 di 2 Samsung 27E510C VGA Port Replacement: passo 7, immagine 2 di 2
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C VGA Port Replacement, VGA Port: passo 8, immagine 1 di 1
    • Gently place the motherboard on a static free surface.
    • It is imperative that this is done on a static free surface, as any discharge of static electricity can 'fry' your motherboard and render it useless.
  9. Samsung 27E510C VGA Port Replacement: passo 9, immagine 1 di 2 Samsung 27E510C VGA Port Replacement: passo 9, immagine 2 di 2
    • Desolder the four regions in the area indicated on the back side of the motherboard using a soldering iron and some desoldering wick.
    • The VGA Port should fall off the board if all of the solder is removed.
  10. Samsung 27E510C VGA Port Replacement: passo 10, immagine 1 di 1
    • If the VGA Port does not fall off the board, try tugging on it with your hand.
    • The VGA Port may be too hot to touch right after desoldering.
    • Excessive tugging could damage the motherboard.
Conclusione
Jesus Blanco
Membro da: 09/27/17
240 Reputazione
2 Guide realizzate
Cal Poly, Team S9-G1, Banghart Fall 2017 Membro di Cal Poly, Team S9-G1, Banghart Fall 2017
CPSU-BANGHART-F17S9G1
6 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 984
