Introduzione
The power adapter port allows power input to the display. The port may need to be replaced if trying a new power adapter cable does not fix display issues.
Cosa ti serve
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
