Introduzione
Because this model does not come equipped with speakers, this port can be used to connect external audio equipment to give your monitor sound. If the audio jack is damaged, connected audio equipment will not operate properly.
Cosa ti serve
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Attrezzo utilizzato in questo passaggio:Heavy-Duty Spudger$4.99
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
