Introduzione
Use this guide to remove the thumbsticks in your Rotor Riot controller.
Cosa ti serve
Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
Remove the iPhone mount.
Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
Lift up the back cover of the controller.
Lift the back cover to a 45 degree angle and place it next to the controller.
Use a spudger to disconnect the phone connector cable from the mainboard.
Remove the shoulder buttons by lifting them out of the case.
Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
Flip over the mainboard and place it above the controller housing.
Use your fingers to remove the left thumbstick by pulling it upwards and off the left joystick.
Repeat this procedure for the right tumbstick.
Repair didn’t go as planned? Check our Answers community for help.
