Salta al contenuto principale
Roku XD 2050X Remote IR LED Replacement
Cosa ti serve
  1. Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: passo 1, immagine 1 di 2 Roku XD 2050X Remote IR LED Replacement, Remote Control Casing: passo 1, immagine 2 di 2
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Roku XD 2050X Remote IR LED Replacement: passo 2, immagine 1 di 2 Roku XD 2050X Remote IR LED Replacement: passo 2, immagine 2 di 2
    • Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
    • Gently twist the spudger to separate the top and bottom halves of the remote.
  3. Roku XD 2050X Remote IR LED Replacement: passo 3, immagine 1 di 1
    • Gently use the spudger to pry the circuit board loose.
  4. Roku XD 2050X Remote IR LED Replacement: passo 4, immagine 1 di 1
    • Using either end of the spudger, gently lift and remove the clear keypad backing.
  5. Roku XD 2050X Remote IR LED Replacement: passo 5, immagine 1 di 1
    • Using either end of the spudger, lift and remove the rubber keypad.
  6. Roku XD 2050X Remote IR LED Replacement, Remote IR LED: passo 6, immagine 1 di 1
    • Desolder the two contacts for the IR LED.
    • Remove the IR LED from the circuit board.
    • For help with soldering view the ifixit soldering guide.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,041
