Salta al contenuto principale
Roku 3 A/C Power Port Replacement
Cosa ti serve
  1. Roku 3 A/C Power Port Replacement, Motherboard: passo 1, immagine 1 di 1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 A/C Power Port Replacement: passo 2, immagine 1 di 3 Roku 3 A/C Power Port Replacement: passo 2, immagine 2 di 3 Roku 3 A/C Power Port Replacement: passo 2, immagine 3 di 3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 A/C Power Port Replacement: passo 3, immagine 1 di 1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 A/C Power Port Replacement: passo 4, immagine 1 di 2 Roku 3 A/C Power Port Replacement: passo 4, immagine 2 di 2
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 A/C Power Port Replacement: passo 5, immagine 1 di 1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 A/C Power Port Replacement: passo 6, immagine 1 di 2 Roku 3 A/C Power Port Replacement: passo 6, immagine 2 di 2
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 A/C Power Port Replacement, A/C Power Port: passo 7, immagine 1 di 2 Roku 3 A/C Power Port Replacement, A/C Power Port: passo 7, immagine 2 di 2
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 A/C Power Port Replacement: passo 8, immagine 1 di 1
    • Desolder the connections of the A/C Power Port on the motherboard.
    • Remove the port.
    • For more information on soldering, check out iFixit's Soldering Guide.
Conclusione
Andy Hak
Membro da: 10/07/16
250 Reputazione
2 Guide realizzate
Cal Poly, Team 15-2, Livingston Fall 2016 Membro di Cal Poly, Team 15-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G2
3 Membri
6 Guide realizzate
Un commento
What’s the size and name of the actual jack? Where do I get a replacement one?
Bo Northwest Designs of SE - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,458
