Salta al contenuto principale
Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement
Cosa ti serve
  1. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: passo 1, immagine 1 di 1
    • Remove the four rubber tabs from the bottom of the sender.
    • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
  2. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
  3. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 3, immagine 1 di 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 3, immagine 2 di 2
    • Flip the device over and remove the top casing from the sender.
  4. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Wireless Audio Module Chip: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
  5. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
  6. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
    • Secure the front speaker input terminal to release the motherboard.
  7. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 7, immagine 1 di 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 7, immagine 2 di 2
    • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
  8. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 8, immagine 1 di 1
    • Flip over the motherboard and wireless audio module chip.
  9. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
    • There should only be a small separation between the white bar and the black retaining flap.
    • Tweezers are recommended for this step.
  10. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement: passo 10, immagine 1 di 1
    • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
  11. Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: passo 11, immagine 1 di 2 Rocketfish RF-WHTIB-A Sender Speaker Input Terminal Replacement, Sender Speaker Input Terminal: passo 11, immagine 2 di 2
    • Desolder the four metallic clasps that attach the panel to the motherboard.
    • For soldering techniques, follow the step in iFixit's soldering guide.
    • Do not attempt to solder if you are inexperienced.
Conclusione
To attach a new speaker input terminal, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Baylor, Team 4-2, Williams Spring 2015 Membro di Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Membri
6 Guide realizzate
1Commento della guida
Where can I get a replacement input terminal?
Greg Surrett (terminal case) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,478
