Salta al contenuto principale
Ridgid R82005 Trigger Switch Replacement
Cosa ti serve
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: passo 1, immagine 1 di 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: passo 2, immagine 1 di 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: passo 3, immagine 1 di 3 Ridgid R82005 Trigger Switch Replacement: passo 3, immagine 2 di 3 Ridgid R82005 Trigger Switch Replacement: passo 3, immagine 3 di 3
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: passo 4, immagine 1 di 3 Ridgid R82005 Trigger Switch Replacement: passo 4, immagine 2 di 3 Ridgid R82005 Trigger Switch Replacement: passo 4, immagine 3 di 3
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G2, Leahy Spring 2019 Membro di USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 410
