Introduzione
The Ridgid R82005 drill has preventative mechanics to cease overheating, although operators may still experience difficulties with the motor due to overloading caused by improperly adjusting both the two speed gear train and torque adjustment ring.
Cosa ti serve
Eject the battery from the drill.
Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
Push the two pins through the motor assembly.
Unsolder the wires from the back of the motor to free the motor from the trigger assembly.
Altre 3 persone hanno completato questa guida.
