Salta al contenuto principale
Ridgid R82005 Motor Replacement
Cosa ti serve
  1. Ridgid R82005  Motor Replacement, Housing Assembly: passo 1, immagine 1 di 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005  Motor Replacement: passo 2, immagine 1 di 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005  Motor Replacement: passo 3, immagine 1 di 2 Ridgid R82005  Motor Replacement: passo 3, immagine 2 di 2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005  Motor Replacement: passo 4, immagine 1 di 2 Ridgid R82005  Motor Replacement: passo 4, immagine 2 di 2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005  Motor Replacement, Motor: passo 5, immagine 1 di 3 Ridgid R82005  Motor Replacement, Motor: passo 5, immagine 2 di 3 Ridgid R82005  Motor Replacement, Motor: passo 5, immagine 3 di 3
    • Push the two pins through the motor assembly.
    • We used an Alan wrench to push the pins through, but any small tool will do.
    • Unsolder the wires from the back of the motor to free the motor from the trigger assembly.
    • To learn how to solder, check out the How to Solder and Desolder Connections guide.
    • Make sure all drill components fit properly in the grooves of the Housing Assembly.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S1-G2, Leahy Spring 2019 Membro di USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 808
