Salta al contenuto principale
Ridgid JobMax R2851 Series B Cord Replacement
Cosa ti serve
  1. Ridgid JobMax R2851 Series B Cord Replacement, Motor: passo 1, immagine 1 di 2 Ridgid JobMax R2851 Series B Cord Replacement, Motor: passo 1, immagine 2 di 2
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Cord Replacement: passo 2, immagine 1 di 1
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Cord Replacement: passo 3, immagine 1 di 1
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Cord Replacement: passo 4, immagine 1 di 2 Ridgid JobMax R2851 Series B Cord Replacement: passo 4, immagine 2 di 2
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Cord Replacement: passo 5, immagine 1 di 3 Ridgid JobMax R2851 Series B Cord Replacement: passo 5, immagine 2 di 3 Ridgid JobMax R2851 Series B Cord Replacement: passo 5, immagine 3 di 3
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Cord Replacement: passo 6, immagine 1 di 2 Ridgid JobMax R2851 Series B Cord Replacement: passo 6, immagine 2 di 2
    • Grip each of the sides of the two green circuit boards and slide them up.
    • Grip each side of the device trigger, and slide it up.
    • You do not need to completely remove these parts. Sliding them upward provides the needed room.
  7. Ridgid JobMax R2851 Series B Cord Replacement: passo 7, immagine 1 di 2 Ridgid JobMax R2851 Series B Cord Replacement: passo 7, immagine 2 di 2
    • Grip the motor firmly and pull towards the back of the tool, rotating back forth until the motor is free.
    • When reinstalling the motor, use a spudger to pull back the brushes. This allows the motor to slide into place.
  8. Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: passo 8, immagine 1 di 3 Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: passo 8, immagine 2 di 3 Ridgid JobMax R2851 Series B Cord Replacement, Motor Brushes: passo 8, immagine 3 di 3
    • Pinch the brush and pry upward away from the center of the part to remove from the device.
    • Take care to not damage the connections on the bottom of the brush.
  9. Ridgid JobMax R2851 Series B Cord Replacement: passo 9, immagine 1 di 2 Ridgid JobMax R2851 Series B Cord Replacement: passo 9, immagine 2 di 2
    • Firmly hold the brush in one hand and pull at the base of the wire to disconnect.
  10. Ridgid JobMax R2851 Series B Cord Replacement, Cord: passo 10, immagine 1 di 1
    • Cut glue holding down the cord.
    • Take care to not damage the casing or cord when cutting the glue.
  11. Ridgid JobMax R2851 Series B Cord Replacement: passo 11, immagine 1 di 1
    • Lift the cord up and out of the device.
  12. Ridgid JobMax R2851 Series B Cord Replacement: passo 12, immagine 1 di 1
    • Cut through each of the two wires connecting the cord to the device.
    • Keep in mind that you should cut the wires far enough down to re-wire the device.
    • Strip the wires and solder the replacement cord.
    • Wrap the soldered area in electrical tape before putting the device back together.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 32
Tutti i Tempi: 796
