Salta al contenuto principale
Ridgid GEN5X R8653 Switch Assembly Replacement
Cosa ti serve
  1. Ridgid GEN5X R8653 Switch Assembly Replacement, Switch Assembly: passo 1, immagine 1 di 1
    • Always disconnect battery and remove saw blade before working on this or any other circular saw. Failure to do so may result in damage or injury!
  2. Ridgid GEN5X R8653 Switch Assembly Replacement: passo 2, immagine 1 di 3 Ridgid GEN5X R8653 Switch Assembly Replacement: passo 2, immagine 2 di 3 Ridgid GEN5X R8653 Switch Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Remove one 7mm T20 torx screw to remove cut depth lever located behind the motor shroud on the left side of the saw.
    • Slowly remove lever from saw ensuring not to lose the compression spring between the lever and retaining screw.
  3. Ridgid GEN5X R8653 Switch Assembly Replacement: passo 3, immagine 1 di 2 Ridgid GEN5X R8653 Switch Assembly Replacement: passo 3, immagine 2 di 2
    • Loosen the angle cut guide lever by pulling it counter clockwise and tilt the base assembly to allow easy access to all housing assembly screws.
  4. Ridgid GEN5X R8653 Switch Assembly Replacement: passo 4, immagine 1 di 1
    • Remove six T20 Torx 20mm screws from the upper housing.
    • Remove three T20 Torx 32mm screws from the upper housing
  5. Ridgid GEN5X R8653 Switch Assembly Replacement: passo 5, immagine 1 di 3 Ridgid GEN5X R8653 Switch Assembly Replacement: passo 5, immagine 2 di 3 Ridgid GEN5X R8653 Switch Assembly Replacement: passo 5, immagine 3 di 3
    • Gently lift away upper housing to expose the internal parts of the saw.
  6. Ridgid GEN5X R8653 Switch Assembly Replacement: passo 6, immagine 1 di 2 Ridgid GEN5X R8653 Switch Assembly Replacement: passo 6, immagine 2 di 2
    • Remove the Phillips #2 screw holding the switch assembly to the lower housing.
    • Remove the four Phillips #2 screws that hold the wires onto the switch.
    • Lift the switch out from the casing.
    • Ensure the two red wires are mounted closest to the trigger mechanism during reassembly.
Conclusione
2 Commenti
The electromagnetic wave spectrum of satellite sensors necessary for successful agricultural activity is not technically implemented, after determining the goals of the business, <a href="https://dragonflyaerospace.com/remote-se..." rel="dofollow ugc">importance of remote sensing in agriculture</a>.
David E. Sanchez - Replica
The electromagnetic wave spectrum of satellite sensors necessary for successful agricultural activity is not technically implemented, after determining the goals of the business, importance of remote sensing in agriculture.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,163
