Salta al contenuto principale
Ridgid GEN5X R8642 Switch Replacement
Cosa ti serve
  1. Ridgid GEN5X R8642 Switch Replacement, Switch: passo 1, immagine 1 di 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Switch Replacement: passo 2, immagine 1 di 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Switch Replacement: passo 3, immagine 1 di 2 Ridgid GEN5X R8642 Switch Replacement: passo 3, immagine 2 di 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Switch Replacement: passo 4, immagine 1 di 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Switch Replacement: passo 5, immagine 1 di 1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Switch Replacement: passo 6, immagine 1 di 1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
  7. Ridgid GEN5X R8642 Switch Replacement: passo 7, immagine 1 di 1
    • Remove the soldered connection from the switch assembly.
  8. Ridgid GEN5X R8642 Switch Replacement: passo 8, immagine 1 di 1
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 301
