Salta al contenuto principale
Retroid Pocket 3 Battery Replacement
Cosa ti serve
  1. Retroid Pocket 3 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
  2. Retroid Pocket 3 Battery Replacement: passo 2, immagine 1 di 3 Retroid Pocket 3 Battery Replacement: passo 2, immagine 2 di 3 Retroid Pocket 3 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
  3. Retroid Pocket 3 Battery Replacement: passo 3, immagine 1 di 2 Retroid Pocket 3 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
  4. Retroid Pocket 3 Battery Replacement: passo 4, immagine 1 di 3 Retroid Pocket 3 Battery Replacement: passo 4, immagine 2 di 3 Retroid Pocket 3 Battery Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
Conclusione
1Commento della guida
Hi, the battery of the Retroid Pocket 3 and 3Plus is customized for the manufacturing company, so it is not possible to find it in online stores and Retroid does not sell it as a spare part. Can you suggest a battery that has similar characteristics such as size, voltage and capacity? The battery is a 755565 3.8V and 4000mAh (for the Retroid 3 and 4500mAh for the 3Plus), can you suggest a 3.7V battery but with similar dimensions? Better a little smaller, otherwise it does not close inside the case. Thanks
Gianluca - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 144
Tutti i Tempi: 4,253
