Salta al contenuto principale
Retina MacBook 2015 Upper Case Assembly Replacement
Cosa ti serve
  1. Retina MacBook 2015 Upper Case Assembly Replacement, Unfasten the lower case: passo 1, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Chiedi a FixBot
    Aggiungi Commento
  2. Retina MacBook 2015 Upper Case Assembly Replacement: passo 2, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 2, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 2, immagine 3 di 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
    Chiedi a FixBot
    Aggiungi Commento
  3. Retina MacBook 2015 Upper Case Assembly Replacement: passo 3, immagine 1 di 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
    Chiedi a FixBot
    Aggiungi Commento
  4. Retina MacBook 2015 Upper Case Assembly Replacement: passo 4, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 4, immagine 2 di 2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    Chiedi a FixBot
    Aggiungi Commento
  5. Retina MacBook 2015 Upper Case Assembly Replacement: passo 5, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 5, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 5, immagine 3 di 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
    Chiedi a FixBot
    Aggiungi Commento
  6. Retina MacBook 2015 Upper Case Assembly Replacement: passo 6, immagine 1 di 1
    • Close the MacBook and carefully flip it upside-down.
    Chiedi a FixBot
    Aggiungi Commento
  7. Retina MacBook 2015 Upper Case Assembly Replacement: passo 7, immagine 1 di 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
    Chiedi a FixBot
    Aggiungi Commento
  8. Retina MacBook 2015 Upper Case Assembly Replacement: passo 8, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 8, immagine 2 di 2
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    Chiedi a FixBot
    Aggiungi Commento
  9. Retina MacBook 2015 Upper Case Assembly Replacement: passo 9, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 9, immagine 2 di 2
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    Chiedi a FixBot
    Aggiungi Commento
  10. Retina MacBook 2015 Upper Case Assembly Replacement: passo 10, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 10, immagine 2 di 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  11. Retina MacBook 2015 Upper Case Assembly Replacement: passo 11, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 11, immagine 2 di 2
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
    Chiedi a FixBot
    Aggiungi Commento
  12. Retina MacBook 2015 Upper Case Assembly Replacement: passo 12, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 12, immagine 2 di 2
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  13. Retina MacBook 2015 Upper Case Assembly Replacement: passo 13, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 13, immagine 2 di 2
    Battery Blocker
    $5.95
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    Chiedi a FixBot
    Aggiungi Commento
  14. Retina MacBook 2015 Upper Case Assembly Replacement: passo 14, immagine 1 di 1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
    Chiedi a FixBot
    Aggiungi Commento
  15. Retina MacBook 2015 Upper Case Assembly Replacement: passo 15, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 15, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    Chiedi a FixBot
    Aggiungi Commento
  16. Retina MacBook 2015 Upper Case Assembly Replacement: passo 16, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 16, immagine 2 di 2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
    Chiedi a FixBot
    Aggiungi Commento
  17. Retina MacBook 2015 Upper Case Assembly Replacement: passo 17, immagine 1 di 1
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
    Chiedi a FixBot
    Aggiungi Commento
  18. Retina MacBook 2015 Upper Case Assembly Replacement, Retina MacBook 2015 Lower Case Assembly Removal: passo 18, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement, Retina MacBook 2015 Lower Case Assembly Removal: passo 18, immagine 2 di 2
    • Use tweezers to peel back the tape covering the display cable connector.
    Chiedi a FixBot
    Aggiungi Commento
  19. Retina MacBook 2015 Upper Case Assembly Replacement: passo 19, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 19, immagine 2 di 2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  20. Retina MacBook 2015 Upper Case Assembly Replacement: passo 20, immagine 1 di 1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
    Chiedi a FixBot
    Aggiungi Commento
  21. Retina MacBook 2015 Upper Case Assembly Replacement: passo 21, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 21, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 21, immagine 3 di 3
    iOpener
    $14.95
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
    Chiedi a FixBot
    Aggiungi Commento
  22. Retina MacBook 2015 Upper Case Assembly Replacement: passo 22, immagine 1 di 1
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
    Chiedi a FixBot
    Aggiungi Commento
  23. Retina MacBook 2015 Upper Case Assembly Replacement: passo 23, immagine 1 di 1
    • Separate the upper case assembly from the lower case assembly.
    Chiedi a FixBot
    Aggiungi Commento
  24. Retina MacBook 2015 Upper Case Assembly Replacement, Audio Jack Board: passo 24, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement, Audio Jack Board: passo 24, immagine 2 di 2
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  25. Retina MacBook 2015 Upper Case Assembly Replacement: passo 25, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 25, immagine 2 di 2
    • Use tweezers to pull the microphone assembly ribbon cable free of its connector.
    Chiedi a FixBot
    Aggiungi Commento
  26. Retina MacBook 2015 Upper Case Assembly Replacement: passo 26, immagine 1 di 1
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
    Chiedi a FixBot
    Aggiungi Commento
  27. Retina MacBook 2015 Upper Case Assembly Replacement: passo 27, immagine 1 di 1
    • Remove the audio jack board.
    Chiedi a FixBot
    Aggiungi Commento
  28. Retina MacBook 2015 Upper Case Assembly Replacement, Dual Microphone Assembly: passo 28, immagine 1 di 1
    • Prepare an iOpener and apply heat to the upper case directly behind the microphone assembly.
    Chiedi a FixBot
    Aggiungi Commento
  29. Retina MacBook 2015 Upper Case Assembly Replacement: passo 29, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 29, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 29, immagine 3 di 3
    • Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case.
    Chiedi a FixBot
    Aggiungi Commento
  30. Retina MacBook 2015 Upper Case Assembly Replacement: passo 30, immagine 1 di 1
    • Remove the dual microphone assembly.
    Chiedi a FixBot
    Aggiungi Commento
  31. Retina MacBook 2015 Upper Case Assembly Replacement, Display Assembly: passo 31, immagine 1 di 1
    • Remove the two 3.3 mm T5 Torx screws securing the display cable assembly.
    Chiedi a FixBot
    Aggiungi Commento
  32. Retina MacBook 2015 Upper Case Assembly Replacement: passo 32, immagine 1 di 1
    • Remove the single 4.3 mm Phillips #00 screw securing the USB-C port ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  33. Retina MacBook 2015 Upper Case Assembly Replacement: passo 33, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 33, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 33, immagine 3 di 3
    • Unfold the USB-C port ribbon cable until it lays flat, allowing access to the bracket beneath.
    Chiedi a FixBot
    Aggiungi Commento
  34. Retina MacBook 2015 Upper Case Assembly Replacement: passo 34, immagine 1 di 1
    • Lift and remove the metal bracket securing the USB-C port ribbon cable connector.
    • During reassembly, be sure the metal tab on the USB-C connector board slides through the slit on the metal bracket.
    Chiedi a FixBot
    Aggiungi Commento
  35. Retina MacBook 2015 Upper Case Assembly Replacement: passo 35, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 35, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 35, immagine 3 di 3
    • Use a spudger to disconnect the USB-C port ribbon cable by prying the connector straight up.
    • Pry from the side nearest the back edge of the MacBook.
    • Remove the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  36. Retina MacBook 2015 Upper Case Assembly Replacement: passo 36, immagine 1 di 1
    • Fully open the display.
    • Set the MacBook down on its right edge with the display facing away from you, as shown.
    Chiedi a FixBot
    Aggiungi Commento
  37. Retina MacBook 2015 Upper Case Assembly Replacement: passo 37, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 37, immagine 2 di 2
    • Remove the four 4.8 mm T8 Torx screws securing the display hinges.
    Chiedi a FixBot
    Aggiungi Commento
  38. Retina MacBook 2015 Upper Case Assembly Replacement: passo 38, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 38, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 38, immagine 3 di 3
    • Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case.
    • There are only a few millimeters of play between the hinges and the case, so you won't need to push far.
    • Push the upper case forward while pulling back gently on the display.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  39. Retina MacBook 2015 Upper Case Assembly Replacement, USB-C Port: passo 39, immagine 1 di 1
    • Remove the single 2.9 mm T3 Torx screw securing the USB-C port to the upper case.
    Chiedi a FixBot
    Aggiungi Commento
  40. Retina MacBook 2015 Upper Case Assembly Replacement: passo 40, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 40, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 40, immagine 3 di 3
    • Slide the USB-C port out of its recess in the upper case, and remove the USB-C port.
    Chiedi a FixBot
    Aggiungi Commento
  41. Retina MacBook 2015 Upper Case Assembly Replacement, Trackpad Assembly: passo 41, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement, Trackpad Assembly: passo 41, immagine 2 di 2
    • Use a pair of tweezers to remove the tape covering the keyboard ribbon cable connector on the trackpad.
    Chiedi a FixBot
    Aggiungi Commento
  42. Retina MacBook 2015 Upper Case Assembly Replacement: passo 42, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 42, immagine 2 di 2
    • Using a spudger, flip open the retaining flap on the keyboard ribbon cable ZIF connector.
    Chiedi a FixBot
    Aggiungi Commento
  43. Retina MacBook 2015 Upper Case Assembly Replacement: passo 43, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 43, immagine 2 di 2
    • Gently pull the keyboard ribbon cable out of its slot in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  44. Retina MacBook 2015 Upper Case Assembly Replacement: passo 44, immagine 1 di 1
    • Remove the five 2.5 mm T3 Torx screws securing the trackpad to the case.
    • Depending on which bit set you use, a T4 driver may fit better. Try both sizes, and use the largest driver that fits fully into the screw head.
    Chiedi a FixBot
    Aggiungi Commento
  45. Retina MacBook 2015 Upper Case Assembly Replacement: passo 45, immagine 1 di 1
    • Remove the trackpad assembly.
    • Metal brackets on each side of the trackpad may fall away during removal. Be sure to position them as shown in the photo during reassembly.
    Chiedi a FixBot
    Aggiungi Commento
  46. Retina MacBook 2015 Upper Case Assembly Replacement: passo 46, immagine 1 di 2 Retina MacBook 2015 Upper Case Assembly Replacement: passo 46, immagine 2 di 2
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF connector.
    Chiedi a FixBot
    Aggiungi Commento
  47. Retina MacBook 2015 Upper Case Assembly Replacement: passo 47, immagine 1 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 47, immagine 2 di 3 Retina MacBook 2015 Upper Case Assembly Replacement: passo 47, immagine 3 di 3
    • Gently peel the keyboard ribbon cable up from the case, and remove the cable.
    Chiedi a FixBot
    Aggiungi Commento
  48. Retina MacBook 2015 Upper Case Assembly Replacement: passo 48, immagine 1 di 1
    • The upper case remains.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
Altre 21 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
92.727 Reputazione
89 guide realizzate
4Commenti sulla guida
please where do i have to put the mushrooms screws? 923-01012
Antonio gaeta - Rispondi Condividi
If you look closely at this image in Step 36 you can see them pretty clearly.
Jeff Suovanen - Rispondi Condividi
I changed the keyboard itself; you follow the instructions to step 35 (skipping 29 to 30, microphone removal) and then remove the keyboard ribbon cable connector to the trackpad (step 45). Maybe the most complicated step is ungluing the black backing stuck to the back of the keyboard and then there are almost a hundred tiny screws holding the keyboard to the frame, mostly only an eye strain. Got the keyboard through ebay (spanish keyboard layout).
Lorenzo Segovia - Rispondi Condividi
I replaced my keyboard and it won’t turn on.
Patrick Cafferky - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 26
Ultimi 30 giorni: 146
Tutti i Tempi: 32,265
