Salta al contenuto principale
Replacing an Atari Capacitor
Cosa ti serve
  1. Replacing an Atari Capacitor, Atari Lynx: passo 1, immagine 1 di 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing an Atari Capacitor: passo 2, immagine 1 di 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing an Atari Capacitor: passo 3, immagine 1 di 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing an Atari Capacitor: passo 4, immagine 1 di 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing an Atari Capacitor, C10 Capacitor: passo 5, immagine 1 di 2 Replacing an Atari Capacitor, C10 Capacitor: passo 5, immagine 2 di 2
    • Desolder the four aluminum tabs and for more information on soldering click here.
  6. Replacing an Atari Capacitor: passo 6, immagine 1 di 1
    • Remove the aluminum back protector to gain access to the C10 capacitor.
  7. Replacing an Atari Capacitor: passo 7, immagine 1 di 2 Replacing an Atari Capacitor: passo 7, immagine 2 di 2
    • Desolder the C10 capacitor.
Conclusione
John Lopez
Membro da: 01/27/14
443 Reputazione
4 Guide realizzate
Cal Poly, Team 1-42, Maness Winter 2014 Membro di Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 4,857
