Salta al contenuto principale
Replacing Atari Lynx Speaker
Cosa ti serve
  1. Replacing Atari Lynx Speaker, Atari Lynx: passo 1, immagine 1 di 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Speaker: passo 2, immagine 1 di 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Speaker: passo 3, immagine 1 di 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Speaker: passo 4, immagine 1 di 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Speaker, Speaker: passo 5, immagine 1 di 2 Replacing Atari Lynx Speaker, Speaker: passo 5, immagine 2 di 2
    • Remove the logic board from the console.
    • Flip the logic board so the screen is facing down.
  6. Replacing Atari Lynx Speaker: passo 6, immagine 1 di 2 Replacing Atari Lynx Speaker: passo 6, immagine 2 di 2
    • Now you will need to desolder both of the wires connected to the speaker.
    • If you are having trouble desoldering, click here.
    • Finally solder the new speaker back on and follow the previous steps in reverse order.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 1-42, Maness Winter 2014 Membro di Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Membri
16 Guide realizzate
2 Commenti
Does anyone know the screw sizes for the lynx 2 console please
RBKing 80 - Replica
What are the specs on the speaker? Size? Wattage?
gregory draudt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,409
