Salta al contenuto principale
Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack
Cosa ti serve
  1. Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Remove cover and headphone jack: passo 1, immagine 1 di 3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Remove cover and headphone jack: passo 1, immagine 2 di 3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Remove cover and headphone jack: passo 1, immagine 3 di 3
    • To remove the cover and the headphone jack, follow the instructions of this guide.
  2. Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the Battery Housing: passo 2, immagine 1 di 3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the Battery Housing: passo 2, immagine 2 di 3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the Battery Housing: passo 2, immagine 3 di 3
    • Disconnect the battery ribbon cable.
    • Using a flat object, squeeze the battery bracket on the side of the headphone jack out of the bracket. It should be a robust flat object as some force is needed to get the battery out. Using too much force can damage the case.
    • Carefully pull out the battery ribbon cable together with the battery.
  3. Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the battery from the housing: passo 3, immagine 1 di 3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the battery from the housing: passo 3, immagine 2 di 3 Replacing Lenovo Yoga Tablet 2 830F or 851F Battery Pack, Removing the battery from the housing: passo 3, immagine 3 di 3
    • Remove the screw cover on the ribbon cable side (the cover is stuck).
    • Remove the screw and cover. The cover is wedged in on one side and therefore you need some patience to get the cover out.
    • The old battery can then be replaced. Pay attention to the type designation of the old and new battery when replacing it.
Conclusione
Repeat the steps in order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Raphael Hinterndorfer
Membro da: 02/11/19
124 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 61
Tutti i Tempi: 3,503
