Introduzione
If your light has gone out and you’ve already changed the battery, the board may have some issues. This guide will show you how to fix circuit problems on an FJ-3LED Globe Electric Push Light which is popular among people for use in attics, basements, closets, cold rooms, cupboards, or storage sheds.
Soldering is required for this guide. If you are unfamiliar or need a refresher, check out this article on How to Solder and Desolder Connections. Be careful when soldering as the iron is very hot and there is a potential to get burned.
Cosa ti serve
Lift the black lid off of the battery slot and remove the batteries.
Attach the disconnected wire to its joint using solder and iron tip. Place the tip of the soldering iron against the solder pad.
Melt enough solder onto the solder pad.
Remove both the solder and the soldering iron tip from the connection as soon as enough solder melts onto the pad.
