Introduzione
This guide requires soldering, and if you do not have experience with soldering you should first read up on this process as it requires the use of a dangerous tool. This guide, How to Solder and Desolder Connections is a helpful resource.
Cosa ti serve
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
If the batty casing solder has been disconnected you will see that the pair of red and black wires near the battery pack are no longer connected.
You will need to solder back on these wires to the two silver soldering plates on the battery case. The black wire should be soldered on to the plate closer next to the square plastic piece attached.
