Salta al contenuto principale
Repairing Quasar Microwave Fan
Cosa ti serve
  1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: passo 1, immagine 1 di 1
    • Disconnect the power supply cord from the outlet.
  2. Repairing Quasar Microwave Fan: passo 2, immagine 1 di 2 Repairing Quasar Microwave Fan: passo 2, immagine 2 di 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Repairing Quasar Microwave Fan: passo 3, immagine 1 di 2 Repairing Quasar Microwave Fan: passo 3, immagine 2 di 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Repairing Quasar Microwave Fan: passo 4, immagine 1 di 3 Repairing Quasar Microwave Fan: passo 4, immagine 2 di 3 Repairing Quasar Microwave Fan: passo 4, immagine 3 di 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
  5. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: passo 5, immagine 1 di 2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: passo 5, immagine 2 di 2
    • Locate the fan in the newly exposed interior.
    • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
    • If the fan does not spin freely, locate what is jamming the fan and remove it.
  6. Repairing Quasar Microwave Fan: passo 6, immagine 1 di 1
    • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
    • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
Conclusione
Melanie
Membro da: 09/26/12
107 Reputazione
2 Guide realizzate
Cal Poly, Team 2-12, Propen Fall 2012 Membro di Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,543
